oil pressure gauge-drops-wheres op sensor?
Old Oct 8, 2010 | 10:43 PM
bggibbs's Avatar
bggibbs
Default oil pressure gauge-drops-wheres op sensor?
My oil pressure just drops to the bottom of the gauge and red light comes.
I can turn trk off and it will wrk again and then while again driving she just drops again.
Where is the oil pressure sensor located on a 99 5.9 360?
Any other ideas on the gauge dropping to the bottom?
Old Oct 8, 2010 | 11:09 PM
J415's Avatar
J415
Next to the dizzy on the passenger side of the truck.
Old Oct 9, 2010 | 12:07 AM
dhvaughan's Avatar
dhvaughan
you might be sucking up a blockage onto the pickup screen that's dropping off when you shut off the truck.
you need to determine, without damaging the motor, whether the oil pressure drop is real, or just a false reading on the gauge. the safest way to do this is to screw in a manual gauge in place of the sending unit.
if the pressure drop is real, you could try changing the oil and filter. it might fix it. if not you'll need to drop the pan and check the screen. since you'll be looking at the oil pump, you might as well replace it.
Old Oct 9, 2010 | 08:25 AM
bggibbs's Avatar
bggibbs
J1415 I didnt knw u knew her.
dhvaughan Dhvaughan I had just put this used eng in 100 miles ago w/ new oil filter.
I asked the guy dropping it to look in the pan and he didnt.
I was wanting to ck the wire on the sensor before going to his shop.
Old Oct 9, 2010 | 10:24 AM
dhvaughan's Avatar
dhvaughan
remove the air filter box so you can see.
look on the passenger side of the distributor, on the top of the block, the oil sending unit is a black vertical cylinder about 1 in ch diameter and 2-3 inches tall. the wire plugs into the top of it.
Old Oct 9, 2010 | 01:33 PM
bigslick050's Avatar
bigslick050
The socket size is 1 1/16
They make a special OP socket that has a rubber boot in it and is deep enough to pull it out. Cost about $10. Some 1 1/16 deep sockets are not deep enough to fit. So I went ahead and got the special socket. No problems..
Old Oct 9, 2010 | 01:59 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Got the Brand and part# handy?
Old Oct 9, 2010 | 08:32 PM
bggibbs's Avatar
bggibbs
yeah, u got any info on where to get it?
Old Oct 9, 2010 | 08:42 PM
dhvaughan's Avatar
dhvaughan
i used an adjustable wrench. but i had the intake off so that might have been cheating
Old Oct 9, 2010 | 08:54 PM
dhvaughan's Avatar
dhvaughan
here's a part number
http://www.thetoolwarehouse.net/p-25...ools-3458.aspx
another
http://shop.advanceautoparts.com/web..._T|GRP2083____
