99 1500 with 230k worth the money?
Old Oct 8, 2010 | 11:17 PM
jasandson's Avatar
jasandson
Default 99 1500 with 230k worth the money?
So i have a chance of getting a 99 1500 5.2 V8 4x4 with 230k for 400bucks Im a tech but specialized on honda's and toyota's so dont kno much about the 5.2L v8 It runs good, i just need a truck for once and awhile house things and to tow my car to the track and back. I kno this truck is nothing compared to my old 8.3L v8 that hauled stuff with no problem, but im sure has the same or more *** then my shop 4.7 V8 5spd.
Bascily any bads about this truck? worth the change and do the 5.2 have power to haul things?
Thanks in advance for the help everyone and yes i am still goin threw all the pages on the forum
Old Oct 8, 2010 | 11:24 PM
pcfixerpro's Avatar
pcfixerpro
Welcome. If it is a running truck for 400, go for it. Even if the transmission goes you can easily part it out and make your money back. If you get tired of parting, most junkyards will buy the truck off of ya.
Old Oct 8, 2010 | 11:34 PM
jasandson's Avatar
jasandson
Yea i kind of figured, he says that the rear brakes are siezed but cyl,drums,shoes probly cost me 150-200bucks, it starts and runs pretty smooth im going to throw some tags take it for a drive see how its shifts and feels
Old Oct 9, 2010 | 12:06 AM
Jr. Mechanic's Avatar
Jr. Mechanic
What do you plan on towing? A 1/2 ton with 230,000 is NOT an ideal tow rig.
Old Oct 9, 2010 | 09:51 AM
lastrights's Avatar
lastrights
5.2 are a strong motor and will run forever ! its just the body will fail before the motor
Old Oct 9, 2010 | 09:52 AM
dhvaughan's Avatar
dhvaughan
it is drivable - if so test drive it and check out the transmission. if it has ANY shifting or slipping problems then think twice - it might be a parts truck only.
assuming trans is ok, and you have the means to fix it up just a little, by all means buy it for $400 bucks. its a 4wd, so get it running and you can sell it for 1000-1500+
towing power with 3.55 gears will be sucky.
Old Oct 9, 2010 | 11:38 AM
jasandson's Avatar
jasandson
Well i just plan on towing a 1400lb car trailer with my 2800lb car on it to the drag strip noting to fancy
Old Oct 9, 2010 | 11:45 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Have the filter and fluid changed(with ATF+4) and get the bands adjusted. Turn OD off when towing. And just change the fluid,do NOT have it flushed.
Old Oct 9, 2010 | 11:52 AM
jasandson's Avatar
jasandson
Yea ill add a trans cooler inline, i dunno about adjusting the bands , i dont want to have to pull the trans. I just kno the older dodges or even any other trucks in the 90s doesnt have good power, but i dont need to race to the track just get it there and not brake down.
Old Oct 9, 2010 | 12:06 PM
zman17's Avatar
zman17
I said "Have the fluid and filter changed" . I did not suggest you do it yourself. Both bands can be easily adjusted during the fluid change process(by a qualified tech), and does not require removal of the tranny.
