CAD reassembly help!!!
Old Oct 11, 2010 | 03:27 PM
matty675's Avatar
matty675
ok guess ill be checking the lines, and or switch. the lines seem a bit difficult to follow tho?
i was under the impression that vac was only applied in 4wd and that the collar had to be installed in the 2wd position, but now i get it
Old Oct 11, 2010 | 03:28 PM
matty675's Avatar
matty675
also, what would case a creaking noise when in 4wd? i think its the front drive shaft.
Old Oct 11, 2010 | 03:36 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I'm pretty sure at some point this link was provided for you, did you bother reading it? http://www.dodgeram.org/tech/repair/..._engagment.htm . And at this point, can we just get through this before you start worrying about any noises.
Old Oct 11, 2010 | 03:51 PM
matty675's Avatar
matty675
haha yes numerous times and i do understand now.
i just need to check the lines and see where im loosing vac. becuz apparently im not getting vac from either line. my evap system may be the cause, idk. there are two vac connections on the canister, one goes to the purge solenoid and the other just goes under the firewall and stops, it doesnt connect to anything, idk if thats supposed to be hooked up to something or not
Old Oct 11, 2010 | 04:09 PM
zman17's Avatar
zman17
You should have a sticker on the radiator support for the emissions. And also read this thread https://dodgeforum.com/forum/2nd-gen...ild-vents.html
Old Oct 11, 2010 | 04:12 PM
matty675's Avatar
matty675
ok man really appreciate the help, i do know you really enjoy helpn me hahaha
Old Oct 11, 2010 | 04:21 PM
zman17's Avatar
zman17
Oh yeah! "I'm Lovin' It" LOL Damn, now I want a couple cheese burgers.
Old Oct 11, 2010 | 09:50 PM
dhvaughan's Avatar
dhvaughan
is any of this still a problem or is all well ?
Old Oct 12, 2010 | 12:42 AM
matty675's Avatar
matty675
haha too funny man
dvaughan-well since the shafts wouldnt lock and wouldnt unlock when i installed the collar over both shafts (4wd position). im guessn im not gettn vac to eithr the red or black line. so i guess ive got a line break somewhere b/w the t-case and manifold, like hey you said. been at work all night and will be able to check it out wednesday. but the good thing is its not leakn yet!-hell yea
Old Oct 12, 2010 | 07:06 AM
dhvaughan's Avatar
dhvaughan
before you open it up. test for vac on the 2 lines at the cad. you have to have vac on one when in 2wd and the other in 4wd. this pushes and pulls the fork back and forth.
if you have vac on both, then i'm guessing your fork is not engaged with the collar.
