Removing Honeycomb Grill Inserts
Old Oct 12, 2010 | 12:29 AM
lblair04's Avatar
lblair04
Default Removing Honeycomb Grill Inserts
Hey all,
I would like to take my grill inserts out and paint them, but I wanted to get some ideas of how you mounted them back in after you ground/cut the plastic off. I was thinking of drilling a small hole in the center of the mount and putting small screws in with washers, but not sure if this is my best bet.
Thanks
Old Oct 12, 2010 | 02:50 AM
dakotas ram's Avatar
dakotas ram
its been ahile since i removed mine, but i put in a billet grille.......your idea sounds pretty good to me, if that doesnt work i would get some kind of plastic epoxy and try that
Old Oct 12, 2010 | 03:26 AM
bigslick050's Avatar
bigslick050
I'm pretty sure the honeycomb inserts are just held by clips and screws at the corners...just undo the hardware and it should come out
Old Oct 12, 2010 | 04:08 AM
dakotas ram
when i took mine off they were plastic welded i believe
Old Oct 12, 2010 | 07:03 AM
Maxx_Magnum's Avatar
Maxx_Magnum
yeah Dakota I believe mine is plastic welded too
