NEED: Complete Fuel Line Upgrade
Old Oct 12, 2010 | 01:04 PM
KY BIGRAM's Avatar
KY BIGRAM
Default NEED: Complete Fuel Line Upgrade
I've seen them on here but not having any luck finding them again.
Problem is I dropped my tank to replace the fuel pump and broke the fuel line connector. I was trying to get away with a replacement from some that the part stores offer but am not having any luck with their junk. So if I'm going to get the complete factory replacement, I may as well upgrade to a better, bigger, stronger line.
Who is carrying the better replacements for my 5.9 2wd?
Old Oct 12, 2010 | 01:10 PM
I am not aware of anyone that makes an 'upgraded' line specifically for our trucks. If you want to replace it with something that is direct fit, the dealer, or, some place like LMC truck is probably going to be your best bet.
If you want to run larger line, you will more than likely have to custom fabricate it yourself.
Old Oct 12, 2010 | 02:56 PM
KY BIGRAM's Avatar
KY BIGRAM
Gotcha. I did find a new connecter that is straight, the original is a 90 degree. I'm going to try and make it work. I hate to get the dealer replacemenr since it is the entire line.
