Front end grind.....
Old Oct 18, 2010 | 03:04 PM
  #31
zman17's Avatar
zman17
Retired Moderator - RIP
And btw! Those dust covers you are getting are just that, DUST covers. They will NOT keep water out.
Old Oct 18, 2010 | 03:07 PM
  #32
95RAM360's Avatar
95RAM360
well when i went, the parts guy had no idea what i was talking about. so i only got the seals...
im done for the night tonight, have to work. and ive made a desicion. My truck is parked until i do the following.
-harmonic Balancer
-Timing Chain
-Axle seals (obviously)
-front seal
-2500 front springs (found a set for $25)
-new leaf springs
-gas guage
-trac bar
-pitman arm
-dual steering stabilizer
-pass. door body work
-alignment
-flush ALL fluids...and get this thing ready for winter.
Old Oct 18, 2010 | 08:22 PM
  #33
dhvaughan's Avatar
dhvaughan
^damn. that's a long list.
if you're really committed to the dust seals, here's a link
http://completeoffroad.com/i-123137-...yspbf-016.html
http://www.riversidegear.com/categor...oduct-719.html
someone found a much heavier, better one, but i've lost it.
i call them mud traps and refuse to use them. i'd just as soon wash my open tubes out with the water hose, or drive through clean water as a "rinse".
Originally Posted by 95RAM360
got some .... brake cleaner, and rags....gunna use a broom with a rag taped at the top and clean the whole tubes...
rags taped to broom handle may not work well. my tubes were a SOLID sludgy mix of dirt, oil, mud, oil, sand, oil, leaves, oil, sticks, and even chunks of wood. wtf.
i used a hooked rod to scrape the tube, end to end to dislodge the muck, then scraped it out, then poured gas in the ends, then sprayed brake cleaner throughout. it took awhile. sheriff made a tool that fit the inner diameter of the axle, but only about 1/3 height and used it as a scraper. very clever. he also came up with the idea of using a come-along to nudge the front diff out of the case, which is a damn tight fit.
Old Oct 18, 2010 | 08:28 PM
  #34
Erm. You seem to have forgotten the link.
Old Oct 18, 2010 | 08:37 PM
  #35
dhvaughan's Avatar
dhvaughan
took me awhile...
Old Oct 18, 2010 | 09:46 PM
  #36
95RAM360's Avatar
95RAM360
ive taken the carrier out twice before.
Zman, i flushed the front diff, after my water encounters....theres not even 3K on the fluid.
also i was told it could also be the vacuum switch on the transfer case, that allows the air flow....he said it could have pressure going through, and to see if theres vacuum at the CAD while running in 2wd.
Old Oct 18, 2010 | 09:50 PM
  #37
dhvaughan's Avatar
dhvaughan
no. water is not entering the vac lines or t-case and making its way into the diff.
axle seals and/or axle vent hose are the leakers.
Old Oct 18, 2010 | 11:48 PM
  #38
95RAM360's Avatar
95RAM360
it was my pass. seal, and vent hose i believe.....hoping this thing will be ok, if not, i have found something very nice for $350...its a dana 60, 4.10 gears, 117K
Old Oct 19, 2010 | 07:30 PM
  #39
95RAM360's Avatar
95RAM360
ok did a small amount today...i didnt tear it apart, instead i checked out the vacuum for the 4x4....
i took off the two small rubber lines that go to the CAD, now my question is, Is it supposed to have vacuum while in 2wd? on the line thats closer to passenger side, i had vacuum that would suck my finger right to the line...good amount of vacuum....now could this be my problem? i found the transfer case switch, and a new one is 15 bucks, so if there isnt supposed to be vacuum then this is my problem....
Old Oct 19, 2010 | 09:36 PM
  #40
dhvaughan's Avatar
dhvaughan
you should have full engine vac on one line in 2wd and the other line in 4wd.
