4X4 Question & Advice requested
Old Oct 15, 2010 | 05:09 PM
Mikem40's Avatar
Mikem40
Default 4X4 Question & Advice requested
I followed the tread on 4wd engagement but i am stuck.
When I shift into 4wd L it does not engage.
I have vacuum at the CAD & transfer case
If I reverse the black & red vacuum lines by the tranny it engages even if in 2 wheel drive/ 4wd light on front drive shaft locked so i know the CAD works
The vacuum switch on the transfer case is new. I am thinking the shifter isn't switching so the vac can be reversed. I am attemping the adjust the shifter.
It is at the end of it throw towards the front. I adjusted back towards the rear w/o any change.
Any & all help welcomed
Thanks
Old Oct 15, 2010 | 05:43 PM
zman17's Avatar
zman17
Retired Moderator - RIP
There is an internal arm/lever called a detent something or other, can't remember off the top of my head right now. That could be the problem.
Poppet plunger detent ball or range fork damage. Not thinking good things for you. If adjusting the shift lever/arm does not work.
BTW, you did not mention if it goes into 4HI ok or not?
Old Oct 15, 2010 | 06:27 PM
does it engage in 4 hi?
Old Oct 15, 2010 | 07:01 PM
zman17's Avatar
zman17
Old Oct 15, 2010 | 07:07 PM
I did read it. Did I miss where he said it works in 4 hi? I sure don't see that mentioned. All I see is that it does NOT work in 4 lo.....
Old Oct 15, 2010 | 07:11 PM
zman17's Avatar
zman17
You missed where I asked if 4HI works.
Old Oct 15, 2010 | 07:27 PM
Mikem40's Avatar
Mikem40
Default 4WD problem
Right now the only way I can get the 4 wd to engage (hi or Low) is to reverse the 2 vac lines @ the tranny. front drive shaft locks & light comes on.
So yes the 4 wd will work but not by the shifter.
I think it is out of adjustment ( it can only be adjusted toward the rear it is at the end towards the front) orthe linkage is binding and the vacuum is not being switched,
I am on the right track?
Old Oct 15, 2010 | 07:34 PM
zman17's Avatar
zman17
Maybe you have the Vac line in the wrong place on the new TC switch. Was it doing this before you replaced the TC vac switch?
Old Oct 15, 2010 | 08:22 PM
Why yes, so I did..... LOL. And here I was searching HIS post........
Its your fault.
Old Oct 16, 2010 | 08:06 AM
Mikem40's Avatar
Mikem40
I had the same issue B4 the TC Vac switch was changed..
It looks like it only fits one way.
I'll take another look.
