how good r u at engine diag
if you have true duals AND NO H-pipe or X-pipe, and you've got smoke out both pipes, then yes you're burning oil on both sides of the engine. this would indicate oil in the plenum.
do you have oil inside your plenum ?
is the gasket sealed, or is it cracked open ?
do you have a pcv valve with a rattle ball in it?
the smoke is every color listed above at idle its white give it some gas its more blue and if u hold it at an rpm it like a blackish gray... dosnt matter anyway i ordered a re ring kit for it 2day pulled the heads and there all carboned up oil is milky so im assuming it the head gaskets, im taking the head to the machine shop tomorrow to have them reworked and checked for cracks then im going to clean the block up real good and check the cylinder walls for cracks,and i have another plenum that i no is good off an old truck that im going to put on.. thamks for all your guys help so far...
I'd be really shocked if the block was cracked. The 360 block can usually be honed out .060 and still be reliable. The 318 block is even beefier. Chrysler Blocks have always been very dependable. I believe I read a Mopar book once that stated Dodge blocks have a Higher than Normal nickel content that provides the durability.
well we got good news and bad news.. the good new engines all apart and parts are ordered.. the bad new is when i dissasmbled the head there a hairline crack between the intake and exhaust valve honestly id b surprised if there wasnt being they always crack there. So now i need to find a head for it i dont want to buy aftermarket or really even new cause this is just my woods truck so if any one has a head for sale out there hit me up haha. And i no the blocks usally dont crack but i got bad luck haha so i always inspect everything real good before putting it back together, now off to the junkyard tomorrow
yes. stock 5.2 and 5.9 heads are exactly the same.
http://cylinder-heads.com/details.cfm?itemid=2275
