door buzzer (how to delete)
Old Oct 15, 2010 | 10:40 PM
dipsherry's Avatar
dipsherry
Default door buzzer (how to delete)
how do you get rid of the annoying buzzer on a 94 ram i am talking about the one that goes off when the driver door is open
Old Oct 15, 2010 | 11:09 PM
Hahns5.2's Avatar
Hahns5.2
In my Dakota it was located on the fuse panel, a black rectangular box thing, I tossed mine. Keep in mind if you do this it won't warn you if you leave the headlights on.
Old Oct 15, 2010 | 11:12 PM
KY BIGRAM's Avatar
KY BIGRAM
The fuse box on the drivers side when you open the door. It is the large black box that is furthest to the front of the truck, unplug it like you would a fuse. I just pull it and leave it in place. That thing is extremely annoying, wish I could fix the one on my '04.
Old Oct 17, 2010 | 07:42 PM
DodgeTheFather Ramthe Daughter's Avatar
anyone know which fuse it is on a 99 ram 1500 ???
Old Oct 17, 2010 | 08:22 PM
dhvaughan's Avatar
dhvaughan
the buzzer/chimer varies by year. on my 01 its inside the CTM central timing module, which is a black plastic box under the dash and beside the ashtray. all chimes come from this box, including seat belt, check engine, low fuel, lights on, door open. caution, don't screw up the CTM, it costs $120.
Old Oct 18, 2010 | 02:14 PM
zaccaglin's Avatar
zaccaglin
I'm almost positive its fuse #13 in my '99 ram. I'll ddouble check when i get home.
Old Oct 20, 2010 | 12:02 AM
dipsherry's Avatar
dipsherry
i tried to pulll the big black box furthest towards the front of my truck and it shut off lights and radio but the buzzing stopped.So i plugged it back in guess i will try fuse 13 next
Old Oct 20, 2010 | 12:07 AM
dhvaughan's Avatar
dhvaughan
careful. i pulled a fuse in my first attempt to silence my door dinger. it might have been 9 or 13, i think it was labeled pw or pdl or power seats or something that i don't even have. it silenced the dinger but removed power from the CTM which caused the intermittent delay control of the wipers to quit working right.
i worked on the damn wipers for a month, replaced column switch and ctm before i figured out it was that stupid fuse. so don't repeat my mistake.
Old Oct 20, 2010 | 12:20 AM
lennemann23's Avatar
lennemann23
If you delete the buzzer you won't be reminded that you left your headlights on when you open your door. Just something to think about.
Old Oct 20, 2010 | 12:01 PM
zaccaglin's Avatar
zaccaglin
I did have mine removed for like a week because i got tired of the door buzzer. This being cause i contently leave my door open with he radio on.... But i had to put it back after leaving my lights on one night....
