1997 Ram 1500 5.2l V8
Old Oct 15, 2010 | 10:51 PM
lennemann23's Avatar
lennemann23
Default 1997 Ram 1500 5.2l V8
Hello. I just bought this Dodge Ram 1500 today and noticed that owner unplugged the check engine light. I plugged it in and noticed that it stayed on. I hooked my OBD II scanner to my truck, and pulled the following codes : P0441, P0713, and another one that I forgot the code to, but my book said Bank 1 Sensor 2. Anyways what should I do with these problems? Where should I start. This is my first truck.
Thanks!
Old Oct 15, 2010 | 11:02 PM
dhvaughan's Avatar
dhvaughan
congrats.
go here, and similar places.
http://www.obd-codes.com/
441 is a evap leak - gas cap, evap vac lines.
bank 1, sensor 2 is the rear O2 sensor.
not sure waht 713 is
Old Oct 15, 2010 | 11:06 PM
lennemann23
Google found this. P0713 Transmission Fluid Temperature Sensor Circuit High Input. What do I do to correct this problem? It seems like going up hills it's slipping in and out of gears.
Old Oct 15, 2010 | 11:11 PM
Search the DIY forum for check valve delete. Get rid of the check valve in the trans cooler lines. It likes to plug up......
Old Oct 15, 2010 | 11:14 PM
lennemann23
So when the check valve becomes clogged, then the fluid can't reach the transmission fast enough to cool it down? Also how do I test the transmission temp. sensor?
Old Oct 16, 2010 | 12:34 AM
95RAM360's Avatar
95RAM360
theres only a dummy light for the tranny....check your fluid as well, and it HAS TO BE in neutral while running to get an accurate reading.......check valve is a 20 minute process very easy, do a search theres a nice DIY with pics here.
