99 dodge 1500 360
Old Oct 14, 2010 | 08:28 PM
suzuki 112's Avatar
suzuki 112
Default 99 dodge 1500 360
bought truck with 93,000 miles on it trans went out at 112,000 t converter went out had one put in , truck does not pull load like it did before about 3,000 pounds , is what i pull every week end .if truck sets for 2 days with out start up ,it will miss until i get it to about 2,000 rpm then it is fine
Old Oct 15, 2010 | 07:53 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Ram section,
FF
Old Oct 15, 2010 | 11:59 AM
When is the last time the truck had a good tune up?
Old Oct 15, 2010 | 05:28 PM
zman17's Avatar
zman17
Retired Moderator - RIP
I wonder if they removed the CPS before removing and installing the trans.
Old Oct 15, 2010 | 05:51 PM
lastrights's Avatar
lastrights
look down throttle body for a pool of oil! welcome to the forum
Old Oct 15, 2010 | 07:17 PM
zman17's Avatar
zman17
Looking down the TB does nothing! Remove it(the TB) and look with a light and a small mirror. Or do the TSB which is useless IMHO.
Old Oct 15, 2010 | 10:36 PM
suzuki 112's Avatar
suzuki 112
truck has not had tune up in a while , the only thing i have done to it as far as tune up has been plugs . me and my dad put trans in our self we did not remove the cps. truck pulled real good until the bearing race in the converter came out and front pump gear. it is realy down on pulling power ,
Old Oct 16, 2010 | 12:43 AM
95RAM360's Avatar
95RAM360
did you only replace the TC? it may be time for a rebuild.....
also check the fluid, check while running in neutral to get an accurate reading.
