Transmission Problems
Old Oct 16, 2010 | 01:59 PM
lennemann23's Avatar
lennemann23
It was red. What is vss?
Old Oct 16, 2010 | 03:33 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Vehicle Speed Sensor/ RWAL sensor. That's not the problem. Could be the Output Speed Sensor on the trans.
Old Oct 16, 2010 | 05:28 PM
lennemann23
I replaced the TSP and it didn't fix it. I checked the fluid in neutral and it was at the minimum line. I filled it up to max and drove it home from the auto part's store. It kept doing it so when I got home I check it and the fluid is at max. I put ATF 4 in it. Wonder what the problem is?
Old Oct 16, 2010 | 08:57 PM
lennemann23
Okay guys. I drove home tonight and it was still doing it. I punched it to 70mph and kept it there and it didn't act up at all. My dad is a ASE mechanic, and he thinks it's a sensor on the transmission that has gone bad. The only code I'm getting is a bad O2 code. What sensor would cause it to want to shift out of 4th to 3rd super fast and then back into 4th? At 70mph and higher it won't do this. Any ideas?
Old Oct 16, 2010 | 10:21 PM
95RAM360's Avatar
95RAM360
maybe the overdrive selenoid is bad....which would require removal of the overdrive assembly, since its located inside the trans.
Old Oct 16, 2010 | 10:28 PM
lblair04's Avatar
lblair04
Why dont you take it to a tranny shop and have them put a scanner on the transmission. Mine was shifting weird and holding onto gears, I got it scanned and it was gov pressure solenoid and transducer...very easy to replace and costs under $150 for both.
Old Oct 16, 2010 | 10:47 PM
lennemann23
I have an OBD II scan tool. It would tell me the code for any transmission error. Is it hard to install the thing your talking about?
Old Oct 17, 2010 | 09:33 AM
zman17's Avatar
zman17
There is a control solenoid and a kick down solenoid listed on Rock Auto.
You have OBD1 so that scanner won't work.
Old Oct 17, 2010 | 10:14 AM
lennemann23
I have a 97 obd 2 came out after 95 right?
Old Oct 17, 2010 | 10:26 AM
dhvaughan's Avatar
dhvaughan
94-95 is obd1.
96+ is obd2.
read through montec's transmission thread at the top. your problem sounds like its constantly hunting the right gear, which might be the gov pressure sensor and solenoid, and other than a fluid/filter change, is one of the few service events that most people, including me, can do to a trans. a fluid change might help, or might be a waste of $50-60.
