sct guys !
Old Oct 18, 2010 | 02:31 PM
  #21
redheadhunter21's Avatar
redheadhunter21
Nope runs about the same, never hits 200, stays around the 180 ish most of the time
Old Oct 18, 2010 | 02:33 PM
  #22
Andrew2500's Avatar
Andrew2500
Thanks. I think I'll stick with the 190 for a while and if I see a need to get the 180, i probably will.
Old Oct 18, 2010 | 11:24 PM
  #23
lastrights's Avatar
lastrights
stupid weather had all my plugs ready to go. i still have the anti seize on ? is it ok that it stayes on them wont be able to get too the plugs till weds night
Old Oct 18, 2010 | 11:25 PM
  #24
lastrights's Avatar
lastrights
and also the metal washer that come with the plugs do the go on a certain way ?
Old Oct 19, 2010 | 01:18 AM
  #25
lblair04's Avatar
lblair04
Im using champion plugs with mine. The only time I ping is when I switch to 93 octane, but get ****ty gas. I switched to a 180 t-stat, but just got switched back after I took my truck back to Aamco for a shifting problem, and the problem ended up being the 180 stat opening around 165 and keeping my truck in the closed loop. I havent had any problems with the 190 or any changes in performance...she still giddy ups and goes!
Old Oct 19, 2010 | 02:10 AM
  #26
Ram_Me's Avatar
Ram_Me
You will run hotter with a more advanced tune and higher stat if you put your engine into a bad position(sitting idling in heat). But, is it even hot in Rhode Island right now? If not, and if it won't warm up there for awhile, just leave it.
Old Oct 19, 2010 | 11:51 AM
  #27
talon6's Avatar
talon6
did you get the 3923's? werent you having a missing problem before?
just remember who told you this..... you will be changing the plugs again in about 3-5k. been through 3 sets of the 3923's. always ended up causing a missfire. i tried to warn you about them before.
Old Oct 19, 2010 | 02:57 PM
  #28
lastrights's Avatar
lastrights
ah really wtf !
i got the autolights because they have a shorter nose and 1 stage colder to help stop ping
should i just go back and get stock champs ?
Old Oct 19, 2010 | 03:01 PM
  #29
jasonw's Avatar
jasonw
Site Moderator
The 3923s have mixed results. Some engines hate them, some seem to do really well with them. My only complaint, personally, is that Autolite is known for pretty iffy quality control.
Old Oct 19, 2010 | 05:57 PM
  #30
Andrew2500's Avatar
Andrew2500
Yeah, It cooled down about halfway through September so I should be good until May for sure. I'll definatly keep an eye on it though this summer. As a volly firefighter my truck tends to idle on the side of the road if I go to the scene of a car accident so I'll def keep the temp in check. Thanks for the help!
