no luck
Old Oct 18, 2010 | 06:14 PM
bearabullion's Avatar
bearabullion
Angry no luck
97 1500 3.9 left it at my gals. it got flooded just over the floorboards ran like a champ but trans had to be gone thru. im a trucker no time to do it myself.a buddy had a flunky !!!!!! that says enough! now it want start just hitting on front right plug! i know it sounds crazy but i need it fixed poured twice what its worth already out. new plugs ,pick up coil, rotor button,cap, coil driving me insane ! bought to burn her down if i dont get some merciful help thanks!!
Old Oct 18, 2010 | 07:20 PM
probably thumped the crank position sensor when dealing with the trans.
Old Oct 18, 2010 | 07:55 PM
dhvaughan's Avatar
dhvaughan
yep. does anyone successfully swap a trans and not bust the crank sensor. seems like not.
Old Oct 18, 2010 | 08:36 PM
J415's Avatar
J415
I did my tranny 4k miles ago and I didn't bump my CPS. Not only that but I installed it in my parking spot with 3 tie down straps (they can hold 1,000lbs each). I looped them around both frame rails and cranked them up. Hows that for McGubber.
Old Oct 19, 2010 | 10:06 AM
bearabullion
Default thank you
if that dosnt workm what else to try ????
Old Oct 19, 2010 | 10:09 AM
Could be any number of things. Need to find out what goes missing. Might be an asd event, caused by a bad sensor, might be pinched wires when the trans was installed. Inspecting everything and make sure all is hooked up, and in the right place would be a good first step. If all appears well, then, test for spark/fuel after cranking for MORE then three seconds.
