What does pinging sound like?
Old Oct 20, 2010 | 08:58 PM
CPTAFW163's Avatar
CPTAFW163
Default What does pinging sound like?
Ever since I put headers on I have heard something that sounds like chatter, but maybe it could be the new acoustics of the exhaust.
It sounds like a faint slapping noise. Metallic.
Is that pinging?
How loud would it be. WOuld you NOT hear it if your windows were rolled down and you are driving at 30 MPH? Because i can't hardly hear it then. Only with the radio off and the windows up.
I think this is paranoia.
Old Oct 20, 2010 | 09:10 PM
siggie30's Avatar
siggie30
Pinging is mostly heard during acceleration in the upper rpm's (under load or WOT). Headers have unique acoustics.
Old Oct 20, 2010 | 09:25 PM
aim4squirrels's Avatar
aim4squirrels
You have a header gasket leak Ill bet. I have one too more days than not. Tighten the bolts and it'll go away for a bit and then it'll return.
Pinging sounds very close to a header leak. So does lifter tick.
Old Oct 21, 2010 | 12:44 AM
jasonw's Avatar
jasonw
Site Moderator
If you were to drop a constant stream of marbles onto a piece of sheet metal, that is what pinging sounds like (usually not quite as loud though).
Old Oct 21, 2010 | 01:52 AM
UnregisteredUser's Avatar
UnregisteredUser
Think of a handful of BB's dropped into a cast iron bathtub.
Old Oct 21, 2010 | 03:02 AM
CPTAFW163's Avatar
CPTAFW163
Yeah, i think it is a header leak. I will tighten them up, and the sound gets better. Then it will come back and i have to retighten.
Well. I guess tightening them will just be a part of my weekly checks.
What is lifter tick? and would that happen to a truck with only 50K miles? I am guessing lifter tick is when they bleed down and can't get filled back with oil.
Old Oct 21, 2010 | 03:04 AM
CPTAFW163's Avatar
CPTAFW163
BTW, this is not only hard acceleration. It is just basically under load. I think it is a header leak.
THese header bolts are really hard to get to.
Old Oct 21, 2010 | 10:26 AM
Maxx_Magnum's Avatar
Maxx_Magnum
Here's what my pinging sounds like
http://www.youtube.com/watch?v=IFZYAbcBr80
Old Oct 21, 2010 | 11:18 AM
talon6's Avatar
talon6
if it is your header bolts, i would get stage8 locking fasteners. they never come loose. i love them. i even put a little antiseize on them before install so i can get them back out. if they keep coming loose its only a matter of time before your header gasket burns out.
http://www.summitracing.com/parts/STG-8915/
and if your gasket is bad, here is the best one to replace it with in my opinion.
http://catalog.remflex.com/MOPAR_Hea...t_p/rf6004.htm
Old Oct 21, 2010 | 12:38 PM
lastrights's Avatar
lastrights
i just installed new plugs autlight 3923 all my problems went away my clatter and the pinging i had ! feels like a new truck ! and now im not afraid to jump on it again hope to try my 93 tune from sct now
also i thought i had an exhaust leak too but after the plugs it went away ! thought it was either drivetran or exhaust ! dunno what was causing that noise !
you have sct too, so maybe plugs get worn quicker ?
