Rear diff rebuild
Old Oct 23, 2010 | 11:36 AM
Capt Chaos's Avatar
Capt Chaos
Default Rear diff rebuild
I have a 2000 Ram 1500 4x4 and the rear diff needs to be overhauled. I'm not sure what exactly needs to be done and I guess I first need to find out what the gear ratio is. All I know is that it is a posi rear. I hope someone can give me some answers.
vin# 1B7HF13Z5YJ169941
Thanks
Old Oct 23, 2010 | 12:32 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF.
Is your Ram an Off Road edition? If so, you have 4.10 gears. If not, you should contact Dodge and get a build sheet for your truck. That will tell you everything it came with from the factory, including the gear ratio. In the subject and comments section of that form, make sure you simply state that you would like a build sheet.
I will move this to 2nd gen (1994-2001 Dodge Rams) to get you any additional help you might need.
Old Oct 23, 2010 | 12:48 PM
Capt Chaos's Avatar
Capt Chaos
I'm not sure if it's an off road addition. How can I tell?
As for that link you provided, it is for US residents only. I'm in Canada. I suppose I could contact a dealership here to find that information.
Thanks for the help.
Old Oct 23, 2010 | 12:54 PM
merc225hp's Avatar
merc225hp
You can open the hood and look up there should be a label with your some of your truck specs on it. It should be something like 3:55, 3:92, 4:10. As for your build sheet go to your closest dealership parts dept with your ins papers and he or she will print it out for free.
Old Oct 23, 2010 | 03:22 PM
UnregisteredUser's Avatar
UnregisteredUser
If it hasn't been removed, there'll be a metal tag on one of the bolts of the diff cover that'll tell you what you've got. Unless, of course, someone swapped gears and for some reason put the original tag back, which is one dumb thing that I've never seen done.
Old Oct 23, 2010 | 03:32 PM
Capt Chaos's Avatar
Capt Chaos
I took a pic to post but it seems my software is acting up so that's a no go. There are 2 tags on the diff. One looks like 3 2 and the other looks like 0.159 or 3.159.
Old Oct 23, 2010 | 04:33 PM
dodgeman52's Avatar
dodgeman52
look in ur glove box and it should say
Old Oct 24, 2010 | 03:10 PM
Capt Chaos's Avatar
Capt Chaos
Thanks, found it in there. Who'd a thunk? lol
The gears are 3:55. Now I just need step by step instructions and I'm all set. Can anyone provide a site where they can be found?
Old Oct 24, 2010 | 03:42 PM
dhvaughan's Avatar
dhvaughan
this is the 8.25 but it pretty much the same.
if you find a good one i'd like to know also. this is on my list of things to do.
http://www.jeepforum.com/forum/f11/c...riteup-933741/
Old Oct 24, 2010 | 04:19 PM
Capt Chaos's Avatar
Capt Chaos
WOW! Looks like a lot of work and with the bad weather coming on, I would hate to tackle something like that outside. I would also need some special tools that I don't have. If I never needed my truck yesterday, I could put this off for a while. I may have to farm the work out.
Thanks for the link.
