ABS problems 2000 Ram 1500
Old Oct 24, 2010 | 01:01 AM
Weekend Wrencher's Avatar
Weekend Wrencher
Default ABS problems 2000 Ram 1500
I need some help. I changed the rotors and pads on my truck 2000 Ram 1500 and after I put it back together, the brake pedal felt good until I started the truck. The ABS light & the parking brake light came on & now the pedal goes all the way to the floor. I bled all four bleeder valves several times and don't have any air bubbles. There were no ABS sensors on the backing plates for the front discs and I didn't do anything to the real brakes. I am completely baffled and frustrated can anyone help. Thank you very much for any advice you can give.
Old Oct 24, 2010 | 09:50 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Ram section,
FF
Old Oct 24, 2010 | 10:05 AM
Pump up the brakes. DO they pump up? Or, does the pedal still go to the floor? If it does, you have a leak in the system somewhere. Need to find that first. (Hint: These trucks are famous for the rear brake line blowing out, right above the gas tank.....)
Old Oct 24, 2010 | 12:40 PM
Weekend Wrencher
Thanks, I pumped the brakes several times and they start to harden up, but after they sit for a minute it goes back to the floor. I will start looking for a leak near the gas tank.
