Axle swap and fuel pump swap
Old Oct 26, 2010 | 11:00 PM
1998ram5.9's Avatar
1998ram5.9
Default Axle swap and fuel pump swap
I was wondering if a dana 44 out of a 1996 ram 1500 4x4 will fit my 1998 ram 1500 that also has dana 44.
Also would the fuelpump from a 1996 ram 1500 318 fit my 1995 ram 1500 with 318?
Old Oct 27, 2010 | 06:25 AM
zman17's Avatar
zman17
Retired Moderator - RIP
There might be some small differences (like the mounting position for the stabilizer links) IIRC, but as long as they are the same gears, you should be fine. As far as the pump goes, there may be a rollover valve issue and the plug might not be the same. They both also need to be the same size gas tank (gallons).
Old Oct 27, 2010 | 09:51 AM
95RAM360's Avatar
95RAM360
^really? so i couldnt get a fuel pump from a 95 that has a 35 gal tank? (mines the 26 gallon)
if so, good to know
Old Oct 27, 2010 | 03:12 PM
1998ram5.9's Avatar
1998ram5.9
hmm ok so im deffinetly gonna get the axle and hopefully the dodge dealer can tell me if there is a difference in fuel pumps
Old Oct 27, 2010 | 05:14 PM
zman17's Avatar
zman17
Just look them up(fuel pumps) on Rock Auto or some other parts store. But, like I said, you have to know the size of the tanks.
