New gear box, still has play at top of box
I put a remaned steering gear box in my truck and I still have the issue of there being play where the steering shaft meets the gear box. You have to move the steering wheel about a quarter turn before the pitman arm moves.
The solution on other post with this problem is adjusting the gear box. My question is should I have to adjust the gear box since I just bought it and should already be adjusted? or is it another issue?
The steering shaft is solid all the way up.
Thank you.
Thank you.
Take a look at this http://dodgeram.org/tech/mods/steeri...ear/Adjust.htm . The Worm Thrust Bearing Preload Adjustment is what is needed. I'd take it back. What brand btw?
I got it from Autozone. Yeah, I will take it out and get another one, hopefully I don't break another pitman arm puller. It took 5 tons of pressure to get the pittman arm off the first time.
