TGC 3" lift install this weekend
Old Oct 28, 2010 | 09:36 PM
slider15004x4's Avatar
slider15004x4
Default TGC 3" lift install this weekend
I am installing my TGC 3" lift and Rough Country dual stabilizer this weekend and just wanted to know if there is anything I need to know. Tips, tricks, things to look out for. Thanks for the help.
Old Oct 28, 2010 | 09:39 PM
TheBigRedOne's Avatar
TheBigRedOne
Follow the instructions. Best tip anyone can give you.
Old Oct 29, 2010 | 01:05 AM
zje400ex's Avatar
zje400ex
Second best tip is to get a case of beer
Old Oct 29, 2010 | 01:42 AM
merc225hp's Avatar
merc225hp
Tips for doing a lift kit, Safety first, Clean area to work in or on.If you have to change the lower control arm's get some new cam bolts before you start, A chain though the coil spring to the frame when you remove it(ever see a spring fly across a shop I have not good),when lowering the axle to remove the spring lower it from the front or behind the wheel opening(don't work in the wheel well when removing the spring). I find it easier if you just remove the swaybar while doing this job. A pickle fork for ball & stud links,If doing add a leaf two extra pin bolts.Gloves, band aids or e tape, Start spraying down all the nuts and bolts day's before you start, Bevey for after the day is done.
Old Oct 29, 2010 | 01:47 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Make sure you have all the bushing for the shocks I didn't and I rode around with half of my truck taller than the rest. They did make it up they overnighted the parts to me of free.
Also a good company to deal with my lift is from there.
Old Oct 29, 2010 | 08:12 AM
slider15004x4
Where can you get cam bolts at?
Old Oct 29, 2010 | 11:33 AM
merc225hp's Avatar
merc225hp
I get mine from the dealer, But I would think that most parts stores have them. There cheap like $4 per bolt and you will need two. If these bolts give you any gruff just bust them off and punch out the old ones. Remember to mark them before you remove them so you can get it to an alignment shop.
Old Oct 29, 2010 | 11:45 AM
slider15004x4
How bad is it going to be in need of an alignment?
Old Oct 29, 2010 | 11:59 AM
merc225hp's Avatar
merc225hp
It is common practice to take the truck to a shop for alignment after a lift is done, It's the first stop you make. So very important.
Old Oct 29, 2010 | 12:16 PM
merc225hp's Avatar
merc225hp
So I was sitting here thinking and why not take the truck into a tire or alignment shop and get a front end inspection done, it should be free. By doing this you will know what kind of shape it's in before you start and then there will be no suprizes when you get the front end alignment done.
