im leaking gas
Old Nov 1, 2010 | 05:16 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1... never could understand why anyone would think removing the bed is easier. One thing to add though. When you put the pump back in, make sure it goes back in the same direction. There should be an arrown on the tank and one on the fuel pump. Or just use a yellow tire marker.
Old Nov 2, 2010 | 08:12 AM
cmckenna's Avatar
cmckenna
Yeah, I see all these people recommending to take the bed off all the time when, I can get the tank out in 15 min flat. It's so easy to do vs. dealing with bed removal.
Oh, and, good thing you mentioned that about the arrow- that's a KEY for pump alignment. I forgot to write that into the process.
CM
Old Nov 2, 2010 | 06:13 PM
zman17's Avatar
zman17
CM
Slacker.....
Old Nov 2, 2010 | 07:16 PM
aim4squirrels's Avatar
aim4squirrels
I tend to leak gas a lot too, clears the room pretty quick.
Old Nov 5, 2010 | 04:31 PM
dakotas ram's Avatar
dakotas ram
i found the problem, there is a small rubber cap on top of the fuel pump assembly that is held on by a hose clamp, the top of it is split in 2...im off to the parts stores to see if i can find another
Old Feb 1, 2011 | 12:08 PM
turbo0001's Avatar
turbo0001
dakotas,
Did you find a replacement cap? I have the same problem. It appears to be a pressure release or something. I'm wondering if that breaking is an indicator of another problem where too much pressure is building up or something.
Old Feb 1, 2011 | 06:24 PM
dakotas ram
ummm, i think i just found a vaccum cap to fit and a hose clamp...... lloked to me to just be old and rotted
