You have to change both front and rear gears. As for what ratio, I would think at least 4:56 but that is just a guess. Someone else on here probably would know what you need to do.
It's not cheap $250x2 for gears, $150x2 for major install kits, 6-8hrs@$75 perhr labor per diff, Gear oil, If you add lsd or lockers $450-$1000 per diff. Hope to blazes they or you don't find anything else wrong or broke when installing the gears. For those tires 4:88 is were I would be.
lol, there is a shop h ere that is very good at prices and also matches everyone else or goes lower and they are fairly big so ill be taking it there.. im not gonna do this one alone
