3.9 swap
Old Nov 3, 2010 | 05:16 PM
villaniller's Avatar
villaniller
Default 3.9 swap
How ya'll are?
I have an '01 3.9L 2wd 5spd pickup that's been to hell and back several times. I have a wrecked donor truck ('98 5.2 4wd Auto). What would I need to swap the engines? Everything in the donor truck is in decent condition, engine is unharmed and runs like a top.
Thanks for your time and much needed help.
Old Nov 3, 2010 | 05:23 PM
Gaius's Avatar
Gaius
I'm not sure of the exact changes from the 98-01 (I know there were a lot of small wiring changes from 97-98), but I would bet that you could take the whole 98 engine/harness/PCM and plug it all in to your 01.
Keep in mind there may be plug style changes and you may have to transfer over some of your 3.9 harness plugs. Also, I'm not sure if the 2001 PCM will integrate with your gauge cluster, but that's an easy swap if not. Hopefully someone can chime in with that info.
Another option is to add in the wiring needed (injectors, extend the alternator and AC wires) to your 3.9 harness and use that, but I think that would be a pain.
Also keep in mind that Federal EPA laws state that you can only use the same year or newer, so if you have emissions testing, they will see it's a 98 PCM.
I'm using a 96 drivetrain in my 98 Jeep, but the PCM is 98 so it can talk to the gauges.
Old Nov 3, 2010 | 05:24 PM
Gaius's Avatar
Gaius
How bad is the 98? Can you swap over the 01 body?
Old Nov 3, 2010 | 05:29 PM
lane's Avatar
lane
you'll need a transmission.
Old Nov 3, 2010 | 07:25 PM
The PCM from the 98 won't work either, it will be expecting an auto trans at the other end of that harness, and won't find it.... that will confuse it, and you will have a perpetual CEL.
Same goes for the wiring harness. The only part out of the donor truck you can use is the engine. Nothing else is the same.
Old Nov 3, 2010 | 07:29 PM
Gaius's Avatar
Gaius
Correct. I was thinking he was swapping everything, including tranny.
The 3.9 harness can easily be adapted to the 5.2 if he's keeping the 5-speed, if one knows wiring and has the books.
Old Nov 3, 2010 | 11:46 PM
crazzywolfie's Avatar
crazzywolfie
i replaced the 3.9 in my 91 with a 5.2 and had to make a motor mount extension plate for the one side. not sure if the 01 would have the same problem but it would not surprise me if it did.
Old Nov 5, 2010 | 09:39 AM
villaniller
Thanks for the help.
I plan on keeping the 5spd tranny. Not a fan of automatics.
What is CEL?
And they don't do emission testing where I'm at, if they change it, I know all the people in town that do the Inspections, so I could get away with it if need be.
Old Nov 5, 2010 | 09:42 AM
villaniller
The 01 body it pretty messed up due to the wreck. All I want is the engine.
Old Nov 5, 2010 | 09:53 AM
zman17's Avatar
zman17
Retired Moderator - RIP
CEL= Check Engine Light
