Replacing ball joints
Old Nov 6, 2010 | 06:00 PM
SyKo450's Avatar
SyKo450
Out of the arm, got it off the spindle no problem, just can't get it out of the arm
Old Nov 6, 2010 | 06:06 PM
J415's Avatar
J415
I get it out of the spindle I used a pickle fork and a 3 lb hammer. Then beat the tar out of it. If it's the ball joint out of the A arm, the ball joint press should pop it right out as long as your using it per instructions.
Old Nov 6, 2010 | 06:17 PM
SyKo450's Avatar
SyKo450
It pops up, not down like the lower, right?
Old Nov 6, 2010 | 06:19 PM
J415's Avatar
J415
The lower pops down. The upper pops up.
Old Nov 6, 2010 | 06:52 PM
SyKo450's Avatar
SyKo450
Bah, you understood lol
Another issue, how the heck do I press the lower one in?
Old Nov 6, 2010 | 07:02 PM
J415's Avatar
J415
Not for nothing, but you should have really researched this BEFORE tackling this project. When I did mine, I used a Ball joint press to take out and put in both my uppers and lowers.
Old Nov 6, 2010 | 07:22 PM
SyKo450's Avatar
SyKo450
Which I have and am using, just not sure how to use it to press in the lower
I did read up on this for the past week, just didn't think I'd be running into these issues
Old Nov 6, 2010 | 08:21 PM
BigDaddy1515's Avatar
BigDaddy1515
I just replaced my upper ball joints, used a Universal Puller/Installer kit that I rented at Advance Auto parts(Bought it then return it for all the money,$159-No scam) Of course I sprayed the entire area down with PB Blaster the day before but the old joint just popped after some pressure with the Puller-C clamp.
Here is an AWESOME tip, I learned from a few guys on this site...Put the ball joints in a freezer the night before install. Once you are ready to install then take them out and they slide right into place, No press needed!!! Just a couple taps with a rubber hammer. Worked like a charm!! I still can't believe it!
Old Nov 6, 2010 | 09:51 PM
SyKo450's Avatar
SyKo450
Thank you for reminding me about the freezer, completely forgot about that, finished one side, tomorrow the other shall be finished
