In the middle of a heater core fix....Help!!!!
Old Nov 9, 2010 | 10:10 AM
losi8ight's Avatar
losi8ight
Originally Posted by Sixtysixdeuce
Good job on gettin 'er done, and now a suggestion; Whatever shop you take it to, do inform them of what you did and advise to double check that the lines into the evaporator are fully connected. I can't even begin to describe how PO'd we get when they blow off in the middle of a service because someone didn't get them shoved on all the way. They can feel quite secure and still not have gotten the spring over the flare.
Ya I will, when I backed the truck out of the garage I found one of those springs on the floor so I have to put that back on. Those sure were fun to get off! lol
Old Nov 9, 2010 | 10:12 AM
losi8ight's Avatar
losi8ight
O ya, and I live the in the north eastern corner of Missouri. About 15min. away from Iowa. Is that close enough because just off hand I cant think of any local shops that do A/C.
Old Nov 9, 2010 | 10:17 AM
zman17's Avatar
zman17
Retired Moderator - RIP
I'm in NH, so that might be a little costly for you to make the trip
Old Nov 9, 2010 | 10:21 AM
losi8ight's Avatar
losi8ight
Haha, ya with my MPG's I could probably get all new A/C components for the same price as gas for the trip. lol Thanks anyways though!
Old Nov 9, 2010 | 11:01 AM
zman17's Avatar
zman17
So what's the mpg's you are getting? Using some oil too by any chance?
Old Nov 9, 2010 | 11:33 AM
losi8ight's Avatar
losi8ight
Actually it uses next to no oil as far as I know and I have a hypertech E-con (waist of money) and it helps maby 1 or 2 mpg's. But the computer says I get about 13mpg. Which is normal as far as I know. I do have a question about the plenum though, if its bad does that mean that coolant would be draining into the oil somehow?
Old Nov 9, 2010 | 12:51 PM
zman17's Avatar
zman17
The overhead is not accurate as far as MPG's go. And no. the plenum(lower intake gasket ) being blown has nothing to do with coolant. Why do you ask?
Old Nov 9, 2010 | 02:09 PM
losi8ight's Avatar
losi8ight
aahh, ok, Im just trying to figure out if the plenum needs replaced and I was thinking that make it drain into the oil. There isnt any coolant in the oil though. Im gonna park my truck for the winter so Ill deal with plenum next year lol
