hello, and my dodge has no spark
Old Nov 14, 2010 | 01:30 PM
dodge6383's Avatar
dodge6383
thank you all for your help, it turned out to be a bad crank sensor. the old one was bad, and the new one i got off ebay was bad too. i put in a new one from pep boys and that one worked. anyone need an ecu? thanks
Old Feb 13, 2011 | 03:53 PM
AGBiggy's Avatar
AGBiggy
i hate when there are no resolutions to this. Same issues here, Anyone with ideas? I have a 95 2500 and tried all the normal tests about volts & OHMS to make sure circuits were good and resistance was within range. Are these computers that delicate that they can fry?
Old Feb 13, 2011 | 04:06 PM
Read the post right above yours.... his problem turned out to be a bad crank sensor.
Old Feb 13, 2011 | 04:20 PM
AGBiggy's Avatar
AGBiggy
Thanks. I must have missed that post. Maybe I will start there although I just replaced mine 2 years ago. Can they go bad that fast and intermittent?
This problem happened a month ago and then just started out of no where a day later while doing nothing.
Old Feb 13, 2011 | 04:26 PM
Did you put in a genuine mopar part? or aftermarket?? Seems these trucks really don't care for the aftermarket pieces.
