46RE shifting problems.. erratic shifting.. shifting too fast ?
Old Nov 8, 2010 | 12:54 PM
candymancan's Avatar
candymancan
Originally Posted by zman17
I've never taken a pan off before. I was just taking a guess. Sorry
No you know more then i have and your probably right, i wasnt trying to be rude if thats what you thought lol. i just said if you have taken a pan off before you would know what i ment by sludge.
Basicly the magnets collect anything metal to it asside from alluminum i think, and the magnet had a thick layer of particles on it which is normal so i was told anyway.
Anyway i found the TV cable and white clip that was mentioned in the link you gave me, how do you get that clip off and once its off i assume like in the link you just move the cable foward or back a notch to adjust it ? Oh and i drove like 50 minutes just now and i cant get the tranny to get hot lol, the fluid and dipstick are warm only must be the cold weather or something fluid tho was on the ok mark so its good..
Old Nov 8, 2010 | 01:30 PM
candymancan
Ok im stumped, if i take that white clip out how do i adjust it ? Do i just push the black thing in or out ? The PDR link doesnt explain how to do it, it just shows where things are
Old Nov 8, 2010 | 02:12 PM
merc225hp's Avatar
merc225hp
This might help you out.
http://bionicdodge.com/Download/Dodg...Adjustment.pdf
Old Nov 8, 2010 | 02:17 PM
BASE ADJUSTMENT PROCEDURE
(1) Turn ignition switch to OFF position.
(2) Remove air cleaner if necessary.
(3) Disconnect cable end from attachment stud.
Carefully slide cable off stud. Do not pry or pull
cable off.
(4) Verify that transmission throttle lever is in
fully closed position. Then be sure lever on throttle
body is at curb idle position.
(5) Pry the T.V. cable lock (A) into the UP position
(Fig. 236). This will unlock the cable and allow for
readjustment.
(6) Apply just enough tension on the T.V. cable (B)
to remove any slack in the cable.Pulling too tight
will cause the T.V. lever on the transmission to
move out of its idle position, which will result
in an incorrect T.V. cable adjustment. Slide the
sheath of the T.V. cable (D) back and forth until the
centerlines of the T.V. cable end (B) and the throttle
bell crank lever (C) are aligned within one millimeter
(1mm) (Fig. 236).
(7) While holding the T.V. cable in the set position
push the T.V. cable lock (A) into the down position
(Fig. 236). This will lock the present T.V. cable
adjustment.
NOTE: Be sure that as the cable is pulled forward
and centered on the throttle lever stud, the cable
housing moves smoothly with the cable. Due to the
angle at which the cable housing enters the spring
housing, the cable housing may bind slightly and
create an incorrect adjustment.
(8) Reconnect the T.V. cable (B) to the throttle
bellcrank lever (C).
(9) Check cable adjustment. Verify transmission
throttle lever and lever on throttle body move simultaneously
Old Nov 8, 2010 | 03:48 PM
candymancan
.Pulling too tight
(1mm) (Fig. 236).
This part confuses me ? What is the throttle bell crank lever ?Where is the centerline on the tv cable ? Seems like there are pictures on this description ? Where did you get it from
Old Nov 8, 2010 | 06:33 PM
candymancan
Ok i figured it out now, how do i get the cable to go to "Stock" if there is such a way ?
Old Nov 9, 2010 | 10:40 AM
I got the procedure directly from the factory service manual. You can download it from the FAQ section here. That will have the pics as well.
Old Nov 9, 2010 | 10:43 AM
zman17's Avatar
zman17
Retired Moderator - RIP
I gave you a link for the factory adjustment in my first post.
Edit, and btw all that sludge you see on the magnet it what causes the Gov sensor and solenoid to not operate correctly.
Old Nov 10, 2010 | 09:55 PM
candymancan
Just wanted to say thanks for all the help, figured out how to adjust the tv cable properly now and I'll change the soleniod and sensor down the road when i get money. I imagine itll be around $200 with fluid
Old Nov 10, 2010 | 09:59 PM
Cwarden07's Avatar
Cwarden07
I pulled my solenoids cover in fine metals all over the little net.Go on ebay best bet foud them for 70 bucks cheaper. Also adjust ur TV cable i did mine and it works wonders. Made mine smoother rather then WOT(wide open throttle).
