2wd lift to clear 35's
Old Nov 10, 2010 | 08:27 PM
dipsherry's Avatar
dipsherry
Default 2wd lift to clear 35's
there is tons of stuff on here to figure out how much lift you need to clear this or that size tire for 4x4... but none for the 2wd. I want to know how much lift do i need to clear a set of 35's on my 94 2wd ram. i plan on 3.5 in coils 1.5 spacers and 5in springs will that work or should i go with the 3.5 coils in front and the 3in spindles
Old Nov 10, 2010 | 09:05 PM
EndIsNear's Avatar
EndIsNear
You'll need about 6" of lift. Maybe 4" with a little rubbing.
Running 3.5" coils and 1.5" spacers would be so rough, it'd be almost undrivable. You can run a spring and spindle, but probably wouldnt be wise to run a spring and spring spacer, at least without fabricated suspension components. 3" coils and 3.5" spindles would give you great clearence, as well as a 3.5" spindles and 3" body lift, or 3" coils and 3" body lift. You can also run spindles and spacers, for say a 4" lift.
Old Nov 10, 2010 | 09:33 PM
dipsherry's Avatar
dipsherry
2 more stupid questions how much lift will the 2500 2wd coils give me.. also will the 4x4 coils fit
Old Nov 10, 2010 | 09:40 PM
redheadhunter21's Avatar
redheadhunter21
yea somewhere around 5" and you should be good, 2.5" on the coils is the largest you can go before needing upper control arms so either a 2.5" spacer or coils with 3in spindles should do it. And a add-a-leaf and/or block for rear.
Old Nov 10, 2010 | 09:44 PM
redheadhunter21
4x4 coils no
Old Nov 10, 2010 | 09:53 PM
dipsherry's Avatar
dipsherry
what about 2500 2wd coils???
Old Nov 10, 2010 | 10:12 PM
dodgeram07's Avatar
dodgeram07
has a buddy put a 3in body lift on his 2wd and then put 35's on..... had to trim the bumper
it also has a litltle bit to do with the rim backspacing and how wide of a tire you got with
i the cheapest way would be a 2in spring spacer and a 3in body lift
the nicest would be a 3-3.5in splinde lift with a 3in coil lift and after maket upper control arm.... then in the rear you would need at least a 4in block or a 2in block and extra leaf pack...2in block ad lift shackles.......or a shackle flip
Old Nov 10, 2010 | 10:15 PM
redheadhunter21
They should fit, not sure on if they will net any lift havent heard anyone doing it and I just got coils from ebay for my truck
