ABS and Air Bag Light problem !!!
Old Nov 10, 2010 | 11:10 PM
Cwarden07's Avatar
Cwarden07
Default ABS and Air Bag Light problem !!!
When I go to slow down or stop the ABS and Air Bag light come one and the RPMS and speedometer go to zero. Whats going on here ? Any help would be greatly appreciated !
Old Nov 10, 2010 | 11:19 PM
Maxx_Magnum's Avatar
Maxx_Magnum
It is most likely the Vehicle Speed Sensor, located on top of the rear end. Several people have had this problem and replacing the VSS usually does the trick. My dad just replaced one in his 99 Ram a few days ago and it fixed it, same things you mentioned with the lights on and speedo not working...
Old Nov 11, 2010 | 03:56 AM
Cwarden07's Avatar
Cwarden07
Hmm ill check that out. Thanks alot !!! Also, I have two ground wires on the passenger side up on the firewall that are juss hanging there ... are these suppose to go somewhere. My dads truck they have them running behind the valve covers and then idk where ... any clues on this !!!
Old Nov 11, 2010 | 08:17 AM
Probably go to the back of the cylinder head. Should be a stud, or something, back there for them to bolt too. Just darn near impossible to see.
Old Nov 11, 2010 | 10:29 AM
Cwarden07's Avatar
Cwarden07
So is it of any importance if i hook these up ??
Old Nov 11, 2010 | 04:31 PM
Yes. Grounds should be... well.... grounded. find a spot, hook 'em up.
Old Nov 11, 2010 | 06:02 PM
zman17's Avatar
zman17
Retired Moderator - RIP
One goes to the back of the head and the other goes too a valve cover bolt.
Old Nov 11, 2010 | 07:44 PM
Cwarden07's Avatar
Cwarden07
ok i was just curious they were just haning there ...
