leaking But were?
Old Nov 13, 2010 | 06:04 PM
byronpen's Avatar
byronpen
Default leaking But were?
OK just got home from work, and my wife was following me, any ways she spotted fluid spraying allover the road, Its Trans fluid-ed for sure. Couldn't see were its coming from for sure as its dark here, but my guess was the main leak is some were between the crack between the Bed of the truck and the cab. What could this be, a hose ect ect. Trans fluid-ed pans at the front, and not leaking Im lost. I mean Spraying its everywhere on everything,
Old Nov 13, 2010 | 06:31 PM
Block the wheels, start the truck, put it in neutral. (set the parking brake if it still works....) have a look, see what you can see. If 'nothing', get some brake cleaner, and clean everything off good. (truck NOT running......) Drive it for a bit, then look and see where the fluid is accumulating.....
Also, check the trans pan bolts. Mine were just finger tight, and some of them, not even that.
Old Nov 13, 2010 | 08:16 PM
dhvaughan's Avatar
dhvaughan
check the location of the drip/spray. common leak places are front seal, rear seal, or cooler line or hose going to the radiator.
don't drive it until you get a handle on it. transmissions are very expensive and running them low will ruin them.
Old Nov 14, 2010 | 11:33 AM
byronpen's Avatar
byronpen
Default Update
thought I give a update. Im a dumb ***, it was a gallon of trans fluid in the bed of the truck that spilled. and got on everything. Thank the lord
Old Nov 14, 2010 | 12:19 PM
charlie1935's Avatar
charlie1935
Expensive rust protection! LOL
Old Nov 14, 2010 | 01:00 PM
Cheap fix at least.
Old Nov 15, 2010 | 06:58 PM
97ramnj's Avatar
97ramnj
lol ^
