How do I remove the headlight covers?
Old Nov 13, 2010 | 11:53 PM
PatriotBSU's Avatar
PatriotBSU
Default How do I remove the headlight covers?
My headlights are very yellowed and in need of a good scrubbing. How to I remove the plastic covers so I can scrub the insides of them as well?
If there is already a how-to guide on this forum, can someone show me the link?
Thanks
Old Nov 14, 2010 | 12:50 AM
jasonw's Avatar
jasonw
Site Moderator
There is no way to take them apart without breaking them, really. The plastic is sealed together.
If you do a search of the forum, you'll find some people that replaced the entire housings (available from various sites and eBay) and some that found some cleaning solutions from their auto parts stores that restored their headlights.
Old Nov 14, 2010 | 03:01 AM
PatriotBSU's Avatar
PatriotBSU
So if one can't take them apart, how does one replace the headlight bulbs if they go out?
Old Nov 14, 2010 | 04:40 AM
TitanOneSeven's Avatar
TitanOneSeven
You can access the back of the headlight housings through the engine bay. The bulbs have a plastic retaining collar that you twist to unlock, after which the bulb can be pulled out of the housing and replaced.
Along with what jasonw said; My lenses are very clouded, and while the cleaning solution did help a bit I found mine to be too far gone to see any real improvement. So I will be taking the replacement route and buying new housings.
Old Nov 14, 2010 | 07:37 AM
bwdakrt's Avatar
bwdakrt
Remove the headlight assembly completely if you want to do it right. Cover the bulb opening in the back with tape to keep out any moisture, wet sand the face of the lenses with 400 grit sand paper, then 600 grit and then finish with 1000 grit. After sanding and drying, high speed buff using a hand drill and buffing pad and about any type of aluminum polish. They will look better than new when you're finished.
Old Nov 14, 2010 | 07:48 AM
VEETEN's Avatar
VEETEN
If you replace them here is a link to a video
https://dodgeforum.com/forum/2nd-gen...d-install.html
Old Nov 15, 2010 | 07:01 PM
97ramnj's Avatar
97ramnj
3M headlight restorer, a plug in drill, and about an hour will have your headlights crystal clear again, the hazing is mainly on the outside of the lense. Ive done it to about 5 cars and trucks so far and it works great! Follow the instructions included with the kit that you can get from any auto parts store which is 19 bucks, youll be very happy
Old Nov 16, 2010 | 07:25 AM
MilesBFree's Avatar
MilesBFree
+1 to what Ramnj said.
If all you want to do is clean up the yellowing and hazing, then just polish them up.
I used the Meguire's kit, and Mothers is flogging their kit pretty heavily on the TV lately and I am sure that one will work nicely too. Haven't tried the 3M one, but would think it will work well too.
Use blue painter's tape to mask off the body and bumper pad; no need to remove them.
Old Nov 16, 2010 | 05:06 PM
97ramnj's Avatar
97ramnj
the 3m works great, it comes with a little roll of green tape to =p
Old Nov 16, 2010 | 05:39 PM
PatriotBSU's Avatar
PatriotBSU
I just used a $10 Turtle Wax headlight kit and they look great. Definitely not brand new, but almost perfectly clear.
