i need some friggin help, grinding noise....
Old Nov 15, 2010 | 03:05 PM
BackwoodsRam's Avatar
BackwoodsRam
hmm id still check the rear pinion, even if the nut is tight id take the drive shaft off and tap it with a hammer to make sure it hasnt started coming out
Old Nov 15, 2010 | 03:16 PM
97ramnj's Avatar
97ramnj
Well i drained my transfer case and no shavings were in it, I popped out the driveshaft and the snap ring is still in there and fine. The pinion nut isn't backing out. So Idk what it could be I sure hope its not the torque converter. Its so weird how it only does it when I back off the gas to a certain point or.hit the gas at a certain point
Old Nov 15, 2010 | 04:02 PM
redheadhunter21's Avatar
redheadhunter21
check the rear end it could be on it way out
Old Nov 15, 2010 | 05:05 PM
97ramnj's Avatar
97ramnj
yeah well im hoping its on its way out, thatll give me an excuse to finally put in my one ton thats been sitting in my garage the gear fluid in the back is actually all gray so it looks like somethings been taking a crap in there. im guna pull it apart tomorrow before i go to atlantic city for my 21st b day =p
zman17's Avatar
zman17
Retired Moderator - RIP
How did you first check the drive shaft ujoints? (truck on ground in park wont cut it) And did you check them again when you had the shaft out?
Old Nov 15, 2010 | 05:06 PM
97ramnj's Avatar
97ramnj
yeah i checked them with the shaft out of the truck, neither of them are loose i got a new shaft with my new axle too
Old Nov 15, 2010 | 05:24 PM
zman17's Avatar
zman17
As long as the joints felt smooth and were not binding in any way or felt rough, I guess you are good in that department.
Old Nov 15, 2010 | 05:54 PM
97ramnj's Avatar
97ramnj
yeah the joints are only about 5 months old anyway, they felt fine. there is some play in the pinion in the back up down side to side. so im going to put my new axle in within the next couple weeks and hope that helps. but i dont understand if it was that why it would only do that when im doing around 55 or above and let off or touch the gas slightly
Old Nov 15, 2010 | 06:02 PM
zman17's Avatar
zman17
Actually,now that I think about it, my 1500 did the same, never did figure it out. It got wrecked before I could. But I always suspected the transfer case.
Old Nov 15, 2010 | 06:22 PM
97ramnj's Avatar
97ramnj
d*mn i was really hoping for a OH I KNOW WHAT IT IS and then i got "truck got wrecked before i figured it out" lol got my hopes up for nothing, well im hoping that its either the pinion which ill figure out if its that when the new axle goes in, or if not transfer case is coming apart when i get some time off of work and im guna take a looksie inside
