i need some friggin help, grinding noise....
Old Nov 15, 2010 | 06:36 PM
  #21
97ramnj's Avatar
97ramnj
anyone else have any great info on this?!
Old Nov 15, 2010 | 07:06 PM
  #22
BackwoodsRam's Avatar
BackwoodsRam
take a 4 or 5 pund hammer and knock the pinion yoke back a bit and re torque the nut on it if u plan on drive the truck very much more cuz if u dont i cud get really bad really fast, and ull be puttin the 1ton rearend in a lot sooner then u think
Old Nov 15, 2010 | 07:11 PM
  #23
97ramnj's Avatar
97ramnj
lol the one tons going in within a week or two weeks, so hopefullyyyy that fixes it. if i still have the noise after im guna be freakin p*ssed
Old Nov 15, 2010 | 07:12 PM
  #24
97ramnj's Avatar
97ramnj
i will try retorquing the nut though
Old Nov 16, 2010 | 12:57 AM
  #25
dhvaughan's Avatar
dhvaughan
when you had the t-case partially opened up, did anything have any front to rear play?
and you said no heavy metal sludge/shavings in the t-case fluid, right ? you caught your fluid in a primary pan and poured it into another container to check for sludge in the primary? and there was none?
my next step would be to put the truck up on 4 jack stands and operate it in gear, trying to duplicate the problem. if you can, then crawl under it and trace the noise. be very careful, moving parts, especially big tires - will kill you.
edit - there should not be any play in the pinion shaft..... none at all.
Old Nov 16, 2010 | 05:00 PM
  #26
97ramnj's Avatar
97ramnj
yeah well there is play in the pinion on the rear axle, so im hoping thats what it is. and i wouldnt be able to safely operate the truck on jack stand as it only doies it around 55 and above, and im not going to spin my tires on jackstands that fast
