Differences between a 1500 and a 2500
The difference in the axles is that on the 2500 you have a floating rear (and front on 4x4). This means that your weight is being supported by the axle housing and not the shaft. It is obviously much stronger and as long as your axle nut is installed properly you can lose a shaft and not the wheel. This beefier set up takes more room which is why you see the larger hubs that protrude through the wheel. A 2500 is referred to as a 3/4 ton, but the capacity can be much higher. My truck has a 3800lbs payload. A 1500 can have a low of 1400lbs max payload. Obviously that is based off the configuration of the truck. A quad cab will have a lower capacity than a regular cab.
The 2500s sit higher for two reasons. The springs obvioulsy give lift, but they also have blocks on the rear axle. Similar to what you would find in inexpensive lift kits these blocks sit in between the springs and the axles to provide more clearance. In the off road world people tend to shy away from blocks because of the problems you can encounter, but these factory blocks seem to work ok.
This site has some good info on the specs of the various models. https://dodgeforum.com/forum/index.php
Someone may have just swapped the badges.
However, on earlier Rams (1994-1995 I believe), there was a 2500 LD, or Light Duty, model that had the same axles (5 lug) as the 1/2 tons. After that, to my knowledge, you could not get a Light Duty 2500, they all came with the heavier axles. What model year(s) are we talking?
Axle nut? On the front maybe but the axle shafts on full floaters rears are held in with a number of bolts. But it is true that on a FF rear you can break an axle shaft and not lose a wheel.
Ram 1500 4x4 also have factory 3" lift blocks in the rear.
Unfortunately.... this is an all to accurate assessment. Unloaded, my truck rides like, well... a truck. With a load on though... MUCH nicer.
So I'm confused, someone said that it can have 5 lug axles because it is in fact a 1994. But someone else said that you can't get 5 lug axles in the 2500, only 8 lug. So who is correct?
I just called the guy to get the vin so we can figure this out before I go to look at it.
Did not know the 2500's had a larger block, I guess I never looked at them that closely.
Full floating: Axle only transfers power, supports no weight. (99% of 4x4 front ends fall into this category.)
Semi-Floating: One end the axle actually supports weight. Typical of most half ton trucks, and almost all live axle, rear wheel drive cars.
Non-floating: These are found at the bottom of some body of water.
