thoughts about transfercase index ring
Old Nov 18, 2010 | 12:01 PM
TRTPLAYER's Avatar
TRTPLAYER
Default transfercase index ring
i was going to get a transfer case index ring i was just wanting to know if anyone else has put one on and which one i should get? i have a 99 dodge with 8" suspension lift
Old Nov 18, 2010 | 12:42 PM
Here's one. Listed for one ton, but, I do believe it will fit your truck as well. This is the least expensive one I have found. Top Gun Customs has one as well, but, its over 200 bucks.
Old Nov 18, 2010 | 03:09 PM
TRTPLAYER's Avatar
TRTPLAYER
thanks
Old Nov 18, 2010 | 05:17 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Don't forget the Transfer Case Saver too.
Old Nov 19, 2010 | 12:54 AM
Kraiger's Avatar
Kraiger
Transfer case saver?
Old Nov 19, 2010 | 01:39 AM
TRTPLAYER's Avatar
TRTPLAYER
ya whats that?
Old Nov 19, 2010 | 01:47 AM
dodgetrucker75's Avatar
dodgetrucker75
awsome lookin ride Kraiger
if you do the index, just keep in mind, your fluid levels, as they will change with the movement of the t-case, and fill plug
Old Nov 19, 2010 | 03:25 AM
Kraiger's Avatar
Kraiger
Thanks. Its getting there,
But yes if you do the index fill the case on the ground before you put it in. Thats what ive done in the past and seems to work good.
Old Nov 19, 2010 | 05:12 AM
UnregisteredUser's Avatar
UnregisteredUser
You need one whether you know it or not. Look here. Buy it. Install it.
