Question about A/F Meter install
Old Nov 20, 2010 | 02:59 PM
  #21
stands2p's Avatar
stands2p
narrowband o2 is 0-1volt.wideband is 0-5volt.4 wire o2 black is signal.tan with white tracer is pcm signal wire @ pcm #3 harness.
Old Nov 21, 2010 | 09:01 PM
  #22
CPTAFW163's Avatar
CPTAFW163
you should use an 18 gauge line splicer to hook that up (from autozone, they are the weatherproof ones with the grease all over them).
THey worked like a charm for me when installing wires for my wideband to the backlight and power wires.
However, since the wire is pretty thin, I would still take some sleeve off the wire coming from the gauge. Then fill with RTV.
Works well.
Old Nov 22, 2010 | 02:50 AM
  #23
J415's Avatar
J415
^ Thanks for the suggestion. I think I'll have to try it, although I must admit, I'm having second thoughts on installing it after seeing some youtube video on narrow band AF meters. They jump around to much to get a reading. I guess I'll just have to find out for myself. You'll know if it didn't work if you see me selling my AF meter in the "parts for sale" section.
