318 performance
Old Nov 21, 2010 | 07:03 AM
loneriderty's Avatar
loneriderty
[QUOTE]What machine shop was silly enough to overbore your engine 80 thousandths? None of them around here will go over 60. Start getting awfully thin on the cylinder walls there....../QUOTE]
well i had a friend do it and he said the same thing you walls are going to be extremely thin but i haven't had a problem yet. and everytime i pull off at a red light my tire come off the ground just like i was after lol
Old Nov 21, 2010 | 01:54 PM
aim4squirrels's Avatar
aim4squirrels
Wow, this thread is filled to the brim with FAIL
Boring .080 is going to gain you about 10ci but significantly reduce the life of the block. If it had to be bored that much, sleeves are in order. My guess is you gained more power with a fresh block and possibly a bit high compression ratio with new pistons, not with the overbore
A quick search of any distributors website will teach you quickly that there is no difference between a 360 and 318 head. Not one bit. The difference in compression on these engines has to do with the piston face design, not the heads.
There are better performance options for your puter than a module from a jeep, and likely it won't control the trans correctly, unless it was designed for a manual.
Old Nov 21, 2010 | 02:22 PM
This guy hasn't been back, and I don't think he is going to be.......
Old Nov 21, 2010 | 08:19 PM
CPTAFW163's Avatar
CPTAFW163
lewt him put in that jeep performance module and see him come back when his truck doesn't run. If the jeep performance module even connects to the wiring harness.
Also, it took a long time to get someone to say that 360 heads are the same as 318 heads.
He will break his truck and be back here.
Old Nov 21, 2010 | 09:00 PM
Gaius's Avatar
Gaius
Maybe it's a carry-over from the LA series blocks then, the FSM says the 5.9 has 1.88in/1.617ex, 5.2 has 1.916in/1.624. No chamber volume given. The guy who did my engine swap harness also advised me the 5.2 heads were an upgrade for the 5.9 because of this.
I wish I had kept my 5.9 valves from my build to check, but I only kept the springs and rockers fro some reason.
edit: Here is a snippet from old post from Evan:
Originally Posted by dakotaparts.com
KB440, WE ARE A MOPAR PERFORMANCE SHOP!!!! The heads are a bit heavy to ship but I would be happy to send you a valve if you would like to put up a little wager, eh? I have taken apart and built over 100 Magnum engines in the last couple of years and found lots of the small valves in 5.9's. I would post a pic of a Brown and Sharpe Vernier Caliper next to a valve but they wont let me post photos...I have no reason to lie and I can damn sure read a micrometer so you tell me...One thing you should know about Dodge is there are no absolutes...I build custom wiring harnesses all the time using MAgnum engine harneses and TJ Wrangler under hood harnesses and they change the wire colors all the time without telling anybody or making any FSM changes...in other words, just because you have 3 pairs of 1.92 heads doesnt mean they are all that size. Ever heard of California emissions? Do you live on the west coast? I have seen lots of strange things done to vehicles speced for CA including different valve sizes, compression ratios and PCM programming.
He's changed the name to BackwoodsOffroad.com, and I trust he knows what he's doing. Swapping these engines is kind of what he does.
Old Nov 21, 2010 | 09:09 PM
matty675's Avatar
matty675
[QUOTE=loneriderty;2325987]
whats your explanation for going that deep into the block?
Old Nov 21, 2010 | 09:53 PM
aim4squirrels
the heads are the same. all magnum heads are the same, unless they are V6.
magnum heads are an upgrade for LA blocks as well, better than using the 5.2L heads on a 5.9L.
Old Nov 21, 2010 | 10:37 PM
Ryans_Dodger's Avatar
Ryans_Dodger
haha... what a dick eh... well I have the same truck and am interested in squeezing some cheap power out of the old girl too.... which is why i came to this thread....so same question but more polite
Old Nov 22, 2010 | 12:01 AM
How fast do you want to spend?
Old Nov 22, 2010 | 01:26 AM
Gaius's Avatar
Gaius
Have you been into all of them?
Just passing on information from someone more experienced than In am. I linked you to the website. Call him and talk to him about it.
