Ram 1500-klicking and jerking
Old Nov 22, 2010 | 05:50 PM
naffey4's Avatar
naffey4
Default Ram 1500-klicking and jerking
I have a 1997 ram 1500 4x4. The problem is when i cut the wheels hard, left or right, there is a loud klicking noise on the pass. side along with jerking. The truck is in 2wd. what could be causing this...bad u joint??
Old Nov 22, 2010 | 05:59 PM
Aubrey's Avatar
Aubrey
Bad u-joint, bad bearing, CAD not disengaging...
Old Nov 22, 2010 | 06:50 PM
naffey4's Avatar
naffey4
What is CAD?
Old Nov 23, 2010 | 05:49 AM
zman17's Avatar
zman17
Retired Moderator - RIP
This will explain what the CAD is http://www.dodgeram.org/tech/repair/..._engagment.htm But I'd also say it's a bad front axle u joint.
Old Nov 23, 2010 | 02:30 PM
naffey4's Avatar
naffey4
Thanls. I will check both.
Old Nov 23, 2010 | 06:23 PM
naffey4's Avatar
naffey4
well took the CAD off and it all looks good to go....moves freely. The vaccum inlet holds pressure and slides the shift fork, and the outlet works as it should. I checked the vaccum lines and they were fine. Truck drives and turns without any vibration or clicks. Its only when I cut the wheels hard to the right is when the clicking and jerking occurs. I guess the next step is to change the u-joints and see if that is the problem.
Old Nov 23, 2010 | 06:24 PM
naffey4's Avatar
naffey4
Is it possiable that the u-joints are binding?
Old Nov 23, 2010 | 06:38 PM
zman17's Avatar
zman17
Yes sir, it sure is.
Old Nov 23, 2010 | 09:00 PM
dhvaughan's Avatar
dhvaughan
wait a minute - don't change the u-joints without proving they are bad. twist the axle u-joints. there should be no play at all. they are likely loose and clicking/clacking.
to check the wheel bearings, grab the top of the tire and shake it in/out as hard as you can. there should be no play. if there is, it might be wheel bearings or it might be ball joints. bad wheel bearings can roar or click or fall off. ball joints don't click much, but might shake and rattle.
Old Nov 24, 2010 | 07:46 AM
naffey4's Avatar
naffey4
This is getting fusterating! Like I mentioned before its only clicking and jerkind when I turn all the way to the rifgt. Drives straight with no shake or vibration! I was searching the internet and found another part that may be the problem...the cad vaccum switch on the transfer case?!? Will have to check that again. There were no apparent leaks. Again it acts like the pass side is still engaged when in 2wd. Thanks again for all of your suggestions. I will keep hunting! Vaughan...I will try what you suggested, but I have shook the wheel with no movement, but will try harder. I am hoping that the ujoint is ok but not to hopeful. Again thanks!
