Alright so someone came over to test drive my truck and i noticed my 4WD isnt working, again. I pull the lever back and the light comes on but the 4WD wont work. What could the problem be?
What makes you think it doesn't work? If the front axle engages (the light comes on) and the front driveshaft locks into the transfer case... it is working......
Pull it harder!
Then put the truck in reverse, pause, back into drive, pause then try it out.
The bad thing about the vacuum system is that there is a slight delay in engagement after pulling 4x4 shifter.
Yes im selling it. The light comes on but its working. We tested it to by driving into the snow and then gunning it and the front tires werent spinning.
