oxygen sensor wiring
Old Nov 24, 2010 | 02:52 PM
  #21
Ground the black probe of your meter on the frame, or some such, 12volt wire goes to one of the white wires. (heater circuit) 5 volt wire goes to sensor black wire. Are the wires on your harness the same colors as the guide I posted above?? (Truck side.)
Old Nov 24, 2010 | 02:59 PM
  #22
autolockguy13's Avatar
autolockguy13
no they arent, but i think i got it figured out now. my colors were black, black/blue, green/orange, and tan/white. i have it hooked up as follows... black to grey, tan/white to black, and the whites are hooked up to the green/orange and black/blue. seemed like the right way to me
Old Nov 24, 2010 | 03:08 PM
  #23
Its a gamble..... I am thinking having it hooked up wrong will really annoy the PCM. Have you tried it yet?
Old Nov 24, 2010 | 03:13 PM
  #24
autolockguy13
i started it and let it idle for a few and drove around the court i live in, didnt go anywhere cause the garage door was still open
  #25
Set any codes? If not, you probably have it set up right.
Old Nov 24, 2010 | 03:18 PM
  #26
autolockguy13
wish i could tell... truck is a mess and cel always seems to be on and cant get it to flash or read codes
Old Nov 24, 2010 | 03:25 PM
  #27
Not sure the key dance works for the 96.......
Old Nov 24, 2010 | 03:34 PM
  #28
autolockguy13
if it does, it doesnt work in my truck
Old Nov 24, 2010 | 04:43 PM
  #29
justfrfun's Avatar
justfrfun
Default O2 wiring
the two white wires are for the o2 heater the grey is signal to pcm the black is ground to pcm
