97 ram 1500 wont start
Old Nov 23, 2010 | 05:00 PM
vishnu's Avatar
vishnu
Angry 97 ram 1500 wont start
Ok i have a 97 ram 1500 4x4 with a 5.9 and it cranks but i have no spark,no fuel, no communication and no check engine light when you turn on the key.The truck sat for a year with a dead battery. Could the PCM be the problem and if so how would i check it to make sure it is the PCM
Old Nov 23, 2010 | 05:57 PM
ASD event most likely. Does the fuel pump prime when you first turn the key on?
Old Nov 23, 2010 | 06:08 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Unscrew the precat o2 sensor and leave it hang, and see what happens.
Old Nov 23, 2010 | 06:13 PM
vishnu's Avatar
vishnu
no the fuel pump doesnt prime when you turn on the key
Old Nov 23, 2010 | 06:15 PM
Swap the ASD relay in the PDC with another one, (they are all pretty much the same.) See if that improves its attitude.
Old Nov 23, 2010 | 06:28 PM
zman17's Avatar
zman17
Since it sat for a year, that's not good. But maybe the Crank sensor (on back of motor) or Cam sensor in the distributor are corroded. Or the cap and rotor are bad or clogged injectors, or rodents chewed a ground wire.
Old Nov 23, 2010 | 08:28 PM
vishnu's Avatar
vishnu
yeah i changed the cam and crank sensor and cap and rotor, i will try and swap the ads relay tomorrow. thanks for the ideas so far
