wheel spacers
Old Nov 23, 2010 | 07:38 PM
dodgeman52's Avatar
dodgeman52
Default wheel spacers
i just got 315/70/17 with 2002 chrome dodge wheels and have alittle bit of rubbing when i make a hard right turn. would it be okay to put 1/4 wheel spacers to help with the rubbing??
Old Nov 23, 2010 | 09:07 PM
I personally don't like wheel spacers. Just don't turn that sharp.
Old Nov 23, 2010 | 09:41 PM
RamSport97's Avatar
RamSport97
I agree, don't do wheel spacers. Maybe look into modifying the wheel wells a bit.
Old Nov 23, 2010 | 10:02 PM
dodgeman52's Avatar
dodgeman52
it only rubs the lower control arm the plastic liner is fine. would it be alright to take a grinder and take alittle of the control arm?
Old Nov 23, 2010 | 10:07 PM
Most certainly not. Those guys hold your front axle in place. Modifying them is really not a good plan.
What you might look at though, is simply replacing them with some tube style control arms. They will be narrower than the stockers, and might give you the added clearance you need. (and a hell of a lot safer than grinding.)
Old Nov 23, 2010 | 10:09 PM
dodgeman52's Avatar
dodgeman52
i was thinkin about gettin longer tube style ones but then they may make the tires scrub on the front bumbper
Old Nov 23, 2010 | 10:10 PM
RamSport97's Avatar
RamSport97
I'm not an engineer so I am not going to tell you if that's safe or not. But I would think it would be fine as long as it was only a little bit, and you gusseted it. I am sure someone in here has some experience.
edit, Hey You is correct. I was stuck in 2wd mode.
Old Nov 23, 2010 | 10:25 PM
If you are at less than 3 inches of lift, just get stock length. Should be fine.
dodgeman52's Avatar
dodgeman52
well it only rubs the lower control arm. i was thinkin about gettin the tube style control arms but im worried that the tires would hit the front bumper cause if i got them i would need to get ones that are 3/4 of inch longer to recenter my axle in the fender well
Old Nov 23, 2010 | 10:28 PM
We are cross-posting each other here.
The front bumper can be moved forward a bit. Just loosen all the bolts, and pull it as far forward as you can, then line everything back up again.
Or, get the long arms, with relocation brackets. (tad more expensive, and more complicated to install, involves cutting off the old mounts, and welding on the new ones....) Then you can center your axle wherever you want.
