In need of desperate help!!
Old Nov 23, 2010 | 11:58 PM
ramthis9501's Avatar
ramthis9501
Default In need of desperate help!!
I pulled off the gauge overlay which included having to remove the needles. I put them back on and the tachometer is not working at all. The battery voltage seems a little off but thats it. How do I fix it?
Old Nov 24, 2010 | 12:07 AM
Lone136's Avatar
Lone136
I'm not sure about now, but back in the day with the old gauges when they would come off you had to replace them and if you were able to get the needle back on it wouldn'y be right. As for the voltage get a volt meter and check it at the alternater and have someone look at the gauge in the truck and tell you what it's reading. Good luck and why would you remove the overlay?
Old Nov 24, 2010 | 12:09 AM
ramthis9501
I got some white LED's to go in there. But with the blue tint it's got on it, it would be light blue and I want it all white. I was told it was removable. But that wasn't the case at all. Just hasn't been my night
Old Nov 24, 2010 | 01:38 PM
ramthis9501
Would resetting the PCM fix it if I pulled the needles and put them all back to zero?
Old Nov 24, 2010 | 02:34 PM
aim4squirrels's Avatar
aim4squirrels
somewhere on the forum there is a needle sweep test procedure, I can't recall the exact details to make it happen, but it was something like hold down the trip ODO button for 6 seconds and turn the key on. See if you can find that test and report back if the needle is working. If not, it isn't getting power.
Old Nov 24, 2010 | 02:53 PM
95RAM360's Avatar
95RAM360
i know its not a dodge, but i did the same to my old 96 Pontiac Sunfire...and my tach, an gas didnt work after....Dealership told me they had to send the cluster out to get "reconfigured".....dont know if we have to do the same with our dodges.
Old Nov 24, 2010 | 02:55 PM
Some of the gauges have a spring on the needle that returns the needle to zero point, and also serves to 'damp' the movement. Normally, the needle is prevented from unwinding by the 'stop' at the zero mark.... pull the needle off, and the spring can fully unwind.....
Are the dodge gauges this way? I don't know. Do the needles move at all when you cycle the key/start the engine?
Old Nov 24, 2010 | 03:44 PM
Might have killed it..... does it move at all?
Old Nov 24, 2010 | 03:45 PM
ramthis9501
All of them except the tach.
Old Nov 24, 2010 | 04:22 PM
redheadhunter21's Avatar
redheadhunter21
try and get ahold of endisnear he went through a similar problem and got it fixed
edit....try this link http://faq.dakota-truck.net/Electron...struments.html
