Shopping List????
Old Nov 24, 2010 | 04:22 PM
forAk's Avatar
forAk
Default Shopping List????
You ever start a job then find out you need to go deeper? Seems like that's been my luck lately!! I got home Tuesday and noticed the steaming engine. Popped the hood and saw anti-freeze peeing out from the water pump housing. Well Wednesday, I get my parts to swap out the water pump and then realized I was an idiot. It wasn't the water pump but the timing chain cover gasket. Man I was pissed! Anyway I tore it all down to the cover last night but realized I needed a puller for the crank pulley. Well, now that I'm that deep into it and am going to Napa on the way home after work, is there anything else I should do or need while I'm in there. I figured I'd do the timing chain and gears, and oil pan gasket. What else do I need for my shopping list besides another bottle of Crown? Thanks guys!
Old Nov 24, 2010 | 04:51 PM
If you are going to drop the pan, might just as well replace the oil pump too......
And lets not forget the freeze plugs behind the engine mounts......
