Old Aug 6, 2015, 02:56 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical System
Print Wikipost
Can "Check Engine" light be reset?
Old Nov 24, 2010 | 09:03 PM
Disconnecting the battery for that long should have done it........
Old Nov 24, 2010 | 09:05 PM
dsulli's Avatar
dsulli
Question Can "Check Engine" light be reset?
My 96, 5.9L triggered the check engine light a week or so ago.
It was the "too cold for too long" code - it never really warmed up.
I changed the thermostat the other day and now it runs just over 200.
I disconnected the battery for a good 45 minutes, but the check engine light is still on and it's still saying "too cold for too long".
thanks,
Old Nov 24, 2010 | 09:35 PM
grupar14's Avatar
grupar14
disconnect the battery and press the brake pedal for 15 to 30 seconds
to reset
Old Nov 24, 2010 | 09:52 PM
J415's Avatar
J415
There you go, doing "IT" again Hey You!!! Answering a question before it's asked. You a freakin' G-E-N-I-U-S!!! So what's your secret?
Old Nov 24, 2010 | 11:56 PM
Try setting your PC's clock back five minutes, and see if it happens to you too.... I am WAY curious what that's all about.
Old Nov 25, 2010 | 09:30 AM
95RAM360's Avatar
95RAM360
lol...like the 7th one ive seen.....
my maxima had a code light on, and i tried disconnecting it for 3 hours, and it would pop back on....then i took the battery out, and left it unhooked for 2 days, and then i had no CEL.....so you may need to let it sit longer....
also ive heard when its disconnected, pull the light switch (to on position) this resets the pcm (so ive been told.)
Old Nov 25, 2010 | 09:54 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Turning the headlights on does not reset the PCM so to speak. It just drains the PCM of any residual power quicker (same as pressing the brake pedal) as mentioned above. Which wipes the memory clean so that it can start fresh. Which is why there is a relearning period.
If the light keeps coming on, it could be the engine coolant temp sensor. A 96 has two, one for the gauge and one that sends a signal to the PCM.
Old Nov 25, 2010 | 10:59 AM
aim4squirrels's Avatar
aim4squirrels
I would make sure you actually fixed the problem first. If you can't get rid of the CEL, there's probably a reason.
