Fancy Interior Stuff...
Old Nov 24, 2010 | 09:41 PM
kuziwr's Avatar
kuziwr
Default Fancy Interior Stuff...
I have a 97 Ram 1500 SLT Laramie. I have to replace the little light inside the steering column, and i just want to know if the interior lights are supposed to slowly fade, along with that light in the column?
Old Nov 24, 2010 | 11:58 PM
Yep. If you get in, close the door, and do nothing...... the lights will slowly fade out after a few minutes. (same thing happens when you get out, but, as you are not in the truck, you just don't notice. )
Old Nov 25, 2010 | 11:50 PM
Nope. My 96 behaves the same way. Guess I wasn't very clear on that huh? The light in the column will shut itself off after a few, or, when you turn the key.
Old Nov 25, 2010 | 11:51 PM
kuziwr's Avatar
kuziwr
Only the light in the steering column does that. Is there something wrong with the time delay relay if the interior lights just shut off when the door closes?
Old Nov 26, 2010 | 12:42 AM
Overstreet's Avatar
Overstreet
what type bulb is the key halo?
Old Nov 26, 2010 | 09:21 AM
zman17's Avatar
zman17
Retired Moderator - RIP
The interior lights are not on a delay, only the key halo.
#1445
Old Nov 29, 2010 | 09:32 AM
Overstreet's Avatar
Overstreet
#1445
thats weird mine has like a 74 bulb which is smaller then the 1445 at the top of the halo
replaced it and still doesnt work
