408 stroker
Old Nov 26, 2010 | 04:11 PM
sam_priem's Avatar
sam_priem
Default 408 stroker
gotta few questions about the 408-
1. will it fit the standard 360 engine mounts in a 96 ram
2. is it compatable with a standard 96 4x4 transmission
3. would it be a decent engine to put in a truck
Old Nov 26, 2010 | 04:19 PM
408 is a stroked 360, so, it will drop right in.
Bolt right up.
Nothing beats the almighty cubic inch.
Old Nov 26, 2010 | 04:22 PM
drewactual's Avatar
drewactual
If you're talking about a mopar 408 stroker and not a ford- it IS a 360- or at least it started life that way. That also answers your second question, and for your third: it depends on what you want from your truck. If its towing torque, yes. If its performance, yes. If its economy- maybe not.
Old Nov 26, 2010 | 06:51 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Why stop at 408?
471 sounds good
http://www.speedomotive.com/ps-616-1...to-471cid.aspx
Old Nov 26, 2010 | 07:14 PM
Originally Posted by Sixtysixdeuce
Oooooooo.... .tempting.... Until I saw the almost 3000 dollar price tag... Ouchie.
Old Nov 26, 2010 | 10:39 PM
RM_Indy's Avatar
RM_Indy
3k, good luck, with a 4.250" bore & 4.200" stroke dont expect to use a little Magnum block for that lol.
471ci is the largest you can go with the biggest R3 block IIRC
Better be prepared to very dig deep on that!
Your talking pretty well 30k build give or take 2k all said n done
Old Nov 27, 2010 | 09:15 AM
EndIsNear's Avatar
EndIsNear
I thought 476 was the biggest you could go with an R3 block?
