help motor
Old Nov 27, 2010 | 09:34 AM
jimbormx's Avatar
jimbormx
Default help motor
i just did a motor swap. it the same motor a 318. i have a 318 in my truck.i took a 318 out of a ram van they are the same.i got everything done but now it is back fireing now i did the cap, wires it seems like it the timing or something maybe the cpus not the same it a 1997 truck and the van motor is 1997 everything fit good help
Old Nov 27, 2010 | 09:37 AM
95RAM360's Avatar
95RAM360
so you didnt use the cpu from the new motor?
Old Nov 27, 2010 | 09:56 AM
jimbormx's Avatar
jimbormx
no i used my cpu out of my truck everything hooked up
Old Nov 27, 2010 | 10:15 AM
Recheck your plug wires. 1 8 4 3 6 5 7 2. Clockwise rotation. Number one is labeled on the cap. (at least, itwas on mine.....)
Old Nov 27, 2010 | 10:24 AM
jimbormx's Avatar
jimbormx
i did the wires im going go see again
Old Nov 27, 2010 | 10:28 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you remove the crank sensor during the swap? Try your old coil too. And don't move the distributor.
Old Nov 27, 2010 | 02:17 PM
jimbormx's Avatar
jimbormx
no i did not use my old crank sensor during the swap.i hope its not that. my buddy did move the distributor.just the cap
Old Nov 27, 2010 | 02:20 PM
zman17's Avatar
zman17
My question was, did you remove the crank sensor before the swap, and reinstall it after? not which one you used. And did "your buddy" move the distributor or not?
Old Nov 27, 2010 | 02:33 PM
crazzywolfie's Avatar
crazzywolfie
i don't know if it is the same or not but i know on the older vans you would have to remove the distributor and carb to remove the engine out of a van.
did the van run before you pulled the engine?
Old Nov 27, 2010 | 02:51 PM
jimbormx's Avatar
jimbormx
no i did not remove the crank sensor.yes we tryed to advance the destributer
