Flex-A-Lite fans....
Old Nov 27, 2010 | 09:35 AM
95RAM360's Avatar
95RAM360
Default Flex-A-Lite fans....
anyone tried these out......i noticed today that one of my blade are bent on my fan....so i found this....just wondering if its big enough/ good enough .....
http://www.summitracing.com/parts/FL...00%7cCID%7c360
Old Nov 28, 2010 | 08:45 AM
HammerZ71's Avatar
HammerZ71
Read a couple of reviews on them a while back, supposed to move more air than stock fan and free up a couple HP due to lighter weight. I'd give it a try...
95RAM360's Avatar
95RAM360
bump...
Old Nov 28, 2010 | 09:12 AM
95RAM360's Avatar
95RAM360
hmmmm....for 25 bucks its worth it....and since one of my fins on my fan is bent, its probably harder for it to spin right?
Old Nov 28, 2010 | 09:59 AM
aim4squirrels's Avatar
aim4squirrels
Not 100% sure it really matters. The stock fan is not evenly spaced blades. If you look closely, you'll see it's divided into a group of 3 and group of 2. Mopar calls this a vicious fan setup, and it supposedly moves more air with less drag on the engine.
I would think that any reduction in weight/rotating mass would be a good thing, but you won't actually gain much. Even deleting the entire fan and going electric fans only nets about 10 ponies.
It's probably a great stock replacement alternative that doesn't net much if any gains, only drawback would be mudding. It simply won't last.
Old Nov 28, 2010 | 10:32 AM
Doesn't the flex fan also eliminate the fan clutch? If so.... not really a good plan.
Old Nov 28, 2010 | 11:24 AM
dodgeram07's Avatar
dodgeram07
is your truck runing hot?,,,, if not i wouldnt change it
Old Nov 28, 2010 | 02:52 PM
aim4squirrels
I think he'd need the fan clutch to mount it. Unfortunately I don't have a 'puter right now to look at the flex fan pics in any detail.
Old Nov 28, 2010 | 07:30 PM
03neonSE's Avatar
03neonSE
http://www.summitracing.com/parts/DCC-4120758/
"Most late 1960s and early 1970s factory-built musclecars were equipped with viscous fans for cooling purposes. Engineers determined through dyno testing that you could gain up to 15 extra horsepower with typical high-performance V8s. These viscous fan packages from Mopar provide thermostatically controlled cooling. They feature a lightweight, balanced fan that uses the least amount of horsepower necessary to turn."
Old Nov 29, 2010 | 04:51 AM
talon6's Avatar
talon6
if even 10hp.
