Multi Questions
Old Nov 28, 2010 | 04:05 PM
byronpen's Avatar
byronpen
Default Multi Questions
Question 1
My gauge that shows my trans fluid works then, Stops, and I get the handy little lite check gauges, ANY Ideas
Question 2
I have a throttle positioning sensor that is bad, were is it located so I can replace it.
Question 3
I broke The handle off my dip stick, auto-zone ect Dont have one, were can I buy one online.
Old Nov 28, 2010 | 04:13 PM
1. Erm, not sure what you are getting at here. Is your trans temp light coming on?
2. Drivers side of the throttle body.
3. Go to the dodge dealer, and order one up.
Old Nov 28, 2010 | 06:50 PM
jasonw's Avatar
jasonw
Site Moderator
Originally Posted by byronpen
Question 1
Unless its an aftermarket gauge, you don't have a trans fluid gauge. I echo HeyYou's question, is the trans temp light coming on?
Question 2
HeyYou is right, it is the sensor on the driver's side of the TB.
Question 3
The Dodge dealer can get you one usually, or you may be able to get one from a junk yard.
